Prop Advice
Hi all, Just fitted a new 4 blade 21P prop to my 186 4.3L. (Original was three blade 23P)
The issue I have is that in everything I have read when u drop the pitch size your RMP should drop as well. However, I am experiencing the opposite. My RMP has increased from 4800 to 5200. At the same time boat speed was dropped by 6-8km/h. Is this normal? Or is something wrong? Or do I just enjoy the change and watch the RMP to stay under WOT. The boat gets out of the hole better and appears to plane at a lower speed. Thanks
Same style of prop: pitch down- rpm up, speed down, hole shot/planning time better.
However, if you change the rake, diameter or number of blades that changes everything.
