HVAC not pumping water 2007 280EC
The HVAC unit has been working fine, turned it on yesterday and no water flow out the side of the boat. The compressor doesn't seem to be running either. The water pump only has 12 volts to it should be 110. Any ideas thanks in advance.
I bench tested the pump with 110v and it functions so I will reinstall tomorrow.
@richardward2006. I've read many of your past posts and you're a savvy boater so I'm sure you'll have thought of many of my suggestions. Anyway, here goes with the first round of suggestions:
You have established that the pump is running and yes they are 110V units.
You have set the thermostat to call for heat or cool. What should happen is the compressor should start running and call for the raw water pump (the 110v unit) to start supplying water. After a short period of time (a few minutes) if the compressor does not receive cooling water it will heat to the point that it will shut off.
Obviously, if it is doing this the thermostat, compressor and 110v water pump are all working and you likely have an air lock or a leak allowing too much air into the system which fails to allow prime - hence no water exiting the through hull fitting. This would be my guess.
If the compressor will not come on when you activate the thermostat you may have a tripped breaker or bad ground (main panel or on the unit itself) or a loose connection of the thermostat wire on the printed circuit board. A remote thermostat sensor is plugged into the printed circuit board with an end like a telephone jack.
If none of this makes any difference I'll look up some other ideas in my manual.
Good luck.
Mark
LG
Richard, I have the manual for the Dometic/Marine Air A/C unit Model Passport I/O Compact&Legacy. I took a couple of pictures of the quick reference Code for settings. I hope this helps. I'll look for more trouble shooting info and post it too if I can find it....as I mentioned in the posts below you should be able to click on the pictures to enlarge and use your cursor to navigate. Good luck!
Richard, I photographed the troubleshooting suggestion pages from the manual. You may have to click on them to enlarge and move your cursor around if you can't read them easily enough. They are good trouble shooting tips for any AC and hopefully will help you solve your issue. Good luck!.....Riuchard, I clicked on the picture and used my cursor to scroll down the page it works great. I'll look through the manual for any other tips that may apply to your issue.
Richard I took two more pictures of pages from the manual. The first is an expanded code list for adjustments. the second is a wiring schematic for my model. Hopefully thy may be of some help and some correlation - at least I hope they provide some ideas....again, good luck! BTW , again clicking on the picture and using your cursor to scroll really helps.
Clogged sea water strainer is another thing that can restrict the water flow enough to cause a failure to prime!
@Rasbury I have had two problems, both of which were easy to fix. I had wonky temperature swings and all I had to do was change the location of the remote temperature sensor and that was fixed. The other main issue I had was loosing prime. particularly after cleaning a strainer and I added a water pressurization port and that issue is fixed. The only other very, very minor issue was when someone would fool around with the control pad and change operating codes but that too was easy to fix. These units are pretty good - knock on wood!
So what do you think was the problem. My guess is the system wasn't priming, and with no water flow, compressor wouldn't come on.
