VP DP Bellow Life Expectancy?
So I have a question about the life expectancy of the main bellow on a Volvo Penta outdrive. I have the new ocean x drives which would have a very similar bellow to the standard DP drive. Mine are going on three years 24/7 in saltwater. Drives serviced annually.
How often do you change your bellows?
Thanks. LG
Thanks. LG
I will help out with what I know. My XDP bellows were awful, even the improved design. They were a bit part of the reason I have the OceanX drives and while I was at it, new engines. The OceanX bellows (glorified DP's I believe) have given no problems at 14 months. I am at the point with this new running gear that I no longer think about them.
Tony
Salt Shaker 342
The longest I have had bellows without replacement it's 3 years only to owning my past new boats no more than three years. This fall will be three years on the new ocean x's. So after that it's all new to me via bellow life expectancy...
I am just trying to get a feel for how long I can get out of the bellows? Thoughts?
Thanks LG!
The bellows on my Volvo DP's were changed after the 7th season in salt water. I'm in NY so boat was in the water from april to november. Upon removal of them they were in better shape than I expected. No signs of leaks or even cracks.
7 years is a good stretch! Anyone get longer?
Thank you!
it is on my list and keeping an eye out for sure....was lift kept when I bought it with 100 hours on it in 10 years, I've put 100 on it since I've had it. They are not cracking and look good- if I kept it in the water it would have been one of the first things I changed....
MT, you're obviously risk averse. There's no doubt you can approach it this way to be on the safe side, but I'm willing to bet 90% of the boats at my marina have bellows that are between 5 years and 10 years old, without problems. This year will be my 5th season in Lake O, and my bellows basically look like new!
I've been told that it is more risky to wet the bellows and take them out of water. UV exposure accelerates degredation, as well as general heat (not surrounded by cold water) and drying out.
This is another good reason to back your boat into your slip, so that the drives are not exposed to direct sunlight.
It depends on the conditions, obviously. But I don't think I will need to replace mine until year 7 or 8.
