winless problems
Got to Cumberland set anchor powered down would not come back up had to raise by hand next day worked fine anybody got any ideas help
The Lewmar guy who rebuilt ours before we even used it pointed out the most common reasons for failure:
(1) trying to drag the boat to windward with the windlass. Always use the boat motor to power over the anchor.
(2) trying to lift a fouled anchor. It's a windlass, not a dragline.
(3) Poor voltage due to corroded connections or undersized feed wire.
(4) Not tying an anchor line strain relief or snubber to a bow chock. Non-stop cyclical strain on the gearbox when anchored will kill it.
That's all I can remember right now but a windlass deserves servicing every few years. If it's been a while you may want to see what it'd take to do that. Mine was a bit of a chore to get out but well worth the reliability we now enjoy. Have a great season, Mike
Marty
Before you do anything ...
I had a similar problem and it was a much simpler solution. My rope was stacking in perfect tight circles and it stacked all the way up to the windlass. Once it touched the bottom of the windlass, it couldn't push anymore into the storage compartment.
Solution, open portal to compartment (behind mirror in v berth) and pull the rope stack down to make space for rest. This doesn't happen often, so you shouldn't have to always do that.
Let us know what you find. Good luck, Mike
gary,
how much was the refurb charge???
2007 rinker 270
"Julie Ann"
Had the same problem....I was lucky....went up front and all it was that the chain/rope was out of the grove. All I had to do was lift the chain and drop it in the middle.
Just sayin. :-D. Mike
I think maybe that's "windlass john"
hes in Bradenton and his number is 941-321-4269
2007 rinker 270
"Julie Ann"
