My to do list for the weekend...perhaps a little beyond
rasbury
Member Posts: 8,816 ✭✭✭✭✭
Brought the boat home to work on a couple of things...one being to re paint the out drives and I will post pictures of where I'm starting from...also want to change the fuel water separator for the genny. There is also another inline filter, I assume the only thing that was on there oem right where the fuel goes into the genny. I'm thinking of yanking that and putting an aftermarket inline filter as that think looks like a pain. I also want to do a little research on checking the torque on the gimbal bearing- after reading one of the other posts on the pivot shaft I believe it was, it had details of how to inspect that. The other thing I want to do is change the engine oil. I have changed the in line and fuel water separator filters a couple weeks ago. I do not have the cool fuel filters to deal with. I did discover that my motor has the quick drain or what ever you call it- the hose that comes from the bottom of the pan to change the oil. To get all the old oil out I would like to use it, so far have just used the line through the dip stick. I see the hose end is fastened somehow up against the transom, I would guess there is a clip or something that holds it in place. To change the oil, do I have to fish that line through the drain plug hole or do I attach the line I used to go through the dip stick and attach it to that hose and suck it out that way? My bow rider had this feature and it was attached to the drain plug so when you pulled it away from the boat it would pull through. I don't see any way to fish that darn thing through the drain plug...
make your life easy, someone who works at the engine manufacture (probably named Bill) designed that engine to run whatever the book calls for. Dont let Bills work be in vain, if the book calls for abc10-80 or whatever, just do it. it will only cost a few bucks more but is money well spent.
What I HATE is when I go to get the oil and they always put the MERCRUISER oil for 6bucks a quart RIGHT NEXT to the wallmart brand at 3bucks a quart
06 Rinker 270
the fellow that sold me the oil asked the same question and I do not have the cats- that being said, when I looked on Amsoil web site, they had to recommendations for that oil and my motor so I'm just not going to take any chances- if the guy won't take it back I'll give i away to someone else...not worth an argument over my motor, that's for sure!
