Replacement ideas for clarion stereo
mskpharmd
Member Posts: 44 ✭✭
hey guys I am considering upgrading my stereo system on my 1999 330. I know the clarion speakers are tired and would like to know what others have done to replace those but I'm also considering changing out the stereo deck itself for something with Bluetooth or aux cord to hook in my music from my iPhone . Any thoughts?
thanks
Mike
thanks
Mike
http://rinkerboats.vanillaforums.com/discussion/2170/added-bluetooth-interface-for-playing-music-from-cell-phone
I am planning on adding the Bluetooth device above this spring. It should be an easy, inexpensive upgrade.
Amazing sound difference. The factory speakers were absolutely toast. Cones dried out and so on. The amps are the only thing left on the boat - but seem to be working fine.
Good luck with your choice.
http://www.amazon.com/Infinity-Reference-612m-High-Performance-Loudspeaker/dp/B00292XT2I/ref=sr_1_2?ie=UTF8&qid=1455563650&sr=8-2&keywords=612+speakers
I replaced everything. Removed the Clarion head unit, CD changer (didn't replace), Clarion 2 channel amp and the 4 6.5's on the deck. Installed a Kenwood head unit, 4 6.5's Infiniti's and also cut in 2 additional 6x9's (Infiniti's as well), 10 inch shallow mount sub and everything is powered through my Alpine PDX-V9 5 channel amp. Front channels are powering my 4 6.5's and the rear is power my 6x9's and then sub channel is powering my sub. I have enough power left on the rear channel to power to 7.7 inch JL's which are going to be installed on my radar arch in the spring.
Basically in the end, depends how serious you are about your sound system. If you enjoy some background noise and don't have a need for good, clean and powerful sound then any class A or B amp will do just fine. Just depends how serious you want to get and what fits your needs. Regardless, I would still run an amp just because it will improve your sound quality tenfold over the headunit alone.
For you guys replacing speakers... are you adding a sub as well? I get nervous about cutting large holes in the boat, and the best place to put the sub and amp. Also.. running wires, power, etc. through the boat seems like it might be a PITA.. but I have a hard time trusting that other people will do the work the "right" way.
I have the same Sony Head unit/speakers combo in my boat that they are installing in the 2016s. It sounds surprisingly good in my boat, but I would really like a sub. -=Mike G.
2014 Rinker 260EC
I went with Bazooka tubes. My brother in-law used to be a professional high end(like $10,000 car set-ups) car and home theater stereo system designer and installer back in the day. Last fall we experimented with some different set ups on my boat to give me some ideas of what I need to buy for the winter or spring install. We experimented with sub enclosures with 10 and 12 inch subs as well as Bazooka tubes. The bazooka tubes had by far the best sound and bass, it was tight and crisp which is hard to get on a big open air boat. Keep in mind most subs are designed for enclosures and need proper air volume and porting. Simply dropping a sub into a fiberglass or wood area that you just happen to have room for on your boat does not guarantee it will sound good. Subs that are marketed as "enclosureless" or not needing a custom enclosure sometimes do the job but sound like **** compared to a custom enclosure or Bazooka tube. A Bazooka tube has already been engineered for proper volume and porting so you can stick one or two just about anywhere and have good tight bass sound. Another benefit of the Bazooka is they can easily be removed or even moved. I am installing two of them under my cockpit bench seat but we also are wiring my cuddy cabin so that I can unplug one of the tubes up on the cockpit deck and install it in my cabin should I want some more intense sound in the cabin.
One other thing to keep in mind, if you plan on installing additional amps and subs you will need to make sure the Sony receiver that you are using has enough RCA output jacks to accommodate the additional speakers. My boat had a fairly nice Alpine unit in it but only had two outputs so I had to buy a new receiver.
The Sony head unit they use has 4RCA outputs.. a Full Range L/R for front and a switchable full range/sub out for the rears. Since I want to be able to fade everything, I like Michael T's idea of the Y-splitters.
Where did you put the amps for the Bazooka tubes? I'd have to find somewhere to put one or two of them, but I like the idea of not cutting any holes. There's another thread I found where someone put a Pioneer shallow enclosure under the rear facing seat behind the drivers seat on a 280. That might work too. I had a set of Bazooka tubes in a SUV back in the 90's and they were awesome then. I think they sell self-amplified ones now too... hmmmm...... -=Mike G
2014 Rinker 260EC
Nmea 2000 connectivity!
Plus app for complete remote control on you apple or android. Play music, channel / band, bluetooth sound from your dock chair! So cool!
Love mine!
