Pre-filling oil filter
I know there is a debate generally on the need to charge an oil filter with oil before installing a new one. On automobiles anyway. Of course I'm not certain how one could pre-fill on my 5.0s since the filters are upside down. And I'm guessing other Merc models are the same? So...thoughts on this debate and whether it is even doable with the positioning of Merc oil filters? I've never pre-filled my filters before but curious about others.
You are 100% correct, the media needs to be saturated before it allows oil to pass through it. If you throw on a new dry filter and then fire up your engine it will take a little while longer for the oil to pass through the dry filter.
So even on an upside down mounted filter you should fill it with oil, let it sit and saturate a few minutes, dump out the oil and then install the filter that way the filter media is prepped.
here comes one of those infamous winded responses...
*popular opinion that I subscribe to is that engine oil is best drained when warm, to excite the particulates held in suspension and to promote more out faster... makes good sense, no?
*shear strength of oil is described as it's ability to adhere to hard parts while resting or in operation. it's what fills the tiny voids between moving parts, allowing the parts constant low friction and consistent tension and disallowing hot spots to form, as the oil is exchanged while the engine is running. While it's not running, shear strength allows exposed metals to be treated against contaminants adhering to them, and this is an important aspect of Marine graded oils.
*a lot if not most engine wear occurs in the seconds an engine is started to when it generates the oil pressure needed, sending it to the places it ought to go.
*an unprimed filter has to be primed by the oil pump before oil heads out to do what engine oil does....... unless:
unless you change oil and filter on a warm engine... and the reason why is the shear properties of the oil, which are adhering to the metals and inside the tiny gaps and protecting the moving parts in the few seconds it takes for the engine to build oil pressure, and then the few seconds more it takes for the filter to be primed.
so.... if you change your oil the poplar opinion way, by warming it up first, there is little reason to concern about pre filling the filter.
make sense?
