342 6.2L Running Rich
Al,
I have an 02 342 with twin 6.2 engines. This past summer I noticed the engines were continuing to run rich after they warmed up. Mostly because of the rich smoke. My mechanic has been working to fix it this winter and has replaced every sensor associated with the ECM, had the injectors checked and cleaned, fuel pressure is 25 psi at the rail, and it is still running rich. Have you had this issue with 6.2's? My mechanic is in contact with Mercruiser and they are leaning toward an intake gasket leak or internal vacuum leak? Any ideas?
Intake leak is easy to find with ether.. small blasts around marrying surface and listen to engine for change in rpm... Doubtful this is your issue... I wager its stat related if you've changed everything else and to no avail, or, even easier- your air filter/spark arrestor is clogged.
they did. Said they had 45 on the front end and 23 on the back end. They pulled the heads and found both cracked around the intake valve stem jurnals leading. They suspect it got hot sometime. May have been previous owner. I've had hard start issues since I've owned it. Thanks for you help
you know the pressure at the rail... you know the delivery rate of the injectors... so, you choose an injector that passes more fuel without changing the spray characteristics of the injector. We're not talking a huge range- we're talking likely 20cc's difference in delivery at an hourly rate. If you're running 25# injectors which are delivering somewhere in the neighborhood of 265cc/hr, a #26 will spray somewhere in the neighborhood of 280cc...
i'd wager that the difference in lift/duration by installing 1.6:1 rockers on a 377 is similar to running 1.5:1 rockers on a 383.
give Bruce at FiveOMotorsports a call, and he'll set you on track... or, if you're feeling industrious: here...
