'06 320EC radar dome height and mounting angle
Please advise a radar dome mounting tower height and mounting angle which work well with the '06 Rinker 320EC. Available towers seem to be 6 or 12 inches, and many come with a 4 degree top plate mounting angle. This is a Great Lakes boat, 5.0 Volvo DP.
Tony
Salt Shaker 342
On my EC 360 it was shimmed forward.
I thought that was a mistake and argued my point with the dealer. They said they'd take the shim out if I really wanted them to but asked me to please do some checking first.
Not sure how many degrees it was shimmed but I suspect 4.
I spoke with Rinker who factory installed the Raymarine, Raymarine HQ and a Power Squadron Radar Course instructor.
They all said most cruisers and certainly my (former) EC 360 runs on plane run at 4 to 5 degrees attitude..... and that I should shim your dome at about 4 degrees.
I put a plastigauge - as seen on all of the boat test captain reports - on my EC 360. It ran at 4 to 5 degrees of attitude when loaded with fuel and water, the goods for the Admiral and I at 3400 rpm - properly trimmed according to the highly accurate Vessel View 7 System. 75% of the time I used the Radar the boat was on plane at 3500 RPM. I used the Radar whenever I was out the boat. The other 25% of the time I was at displacement RPM of about 1200.
If I had pulled the shim I would have been shooting the location of sea gulls 75% of the time - when going faster.....and IMO going faster is when the radar really shines as at 35 MPH with a boat I NEED a forward look..... at 5 MPH it's just nice to have a forward look.
At displacement speed it was not nearly as important to have accurate radar for MY uses.
Only once have I been caught in "soup" where I had to go slow - because I listen to the weather forecasts, go to the VHF for the area I intend to boat and use the Radar to see what's ahead.
Yes, one can get caught by surprise despite one's best plans, but I don't adjust anything for the 1% of the time that is exceptional. In a case like that I take other known marine measures to stay safe.
IMO shim it for on plane speed if that's what you do the most of and want the safety of forward vision at speed.
