On my 260EC the head and AC pick ups are the same size. Theoretically you can use the same pick up as long as you don't use your head at the same time the AC is running. If the flow is low to the AC there should be protection and the compressor should shut off.
I'm not sure if air can be drawn from the head. It shouldn't if everything is working properly.
Anyhow I would rather have a dedicated pick up. There's lots of shoulds in my discussion above and something is bound to go wrong sooner or later.
I get that now. i am just thinking that instead of a bilge I can run the ac pic kup from the same spot in the boat. not saying same water pick up will be shared just another added in the opposite side
can I use same pickup when I install ac?
