bilge pumps 2005 270 vista's vee
Can anyone help. I have two bilge pumps on my boat. And have had a strange issue with them. When I bought the boat a year ago I has a survey done one of the issues picked up was the pump under the berth in the cabin was not working. No issues I was going to change it but just did not get round to it. The bilge pump in the engine bay used to operate when I used the switch at the helm position, so no issues. Well a strange thing has happened. When I operate the switch at the helm position, the pump in the engine bay no longer works, although it does work automatically (an engineer has looked at it and checked by f putting water in engine bay) this was pumped out on the port rear side where it always has. However it does not work anymore by operation the switch at the helm position. However apparently my pump in the cabin has now started to work and they have stated that they can feel air (no water in hull) coming out of the hole on the mid starboard side.
So the question is should the switch on the helm position operate both pumps? And if so any ideas why it now does not operate the pump in engine bay. Or have i just had a gremlin and it is now operating as it should do.
the question is how are the bilge pump connected, is it a split IE from switch one lot of wiring running to mid pump and another to the aft pump? or is it a continuous circuit and if so in what direction aft to forward or other way round?
Thanks in advance
The only issue for me with the smart pump is it uses more battery power checking all the time. It is why I just replaced mine again with a regular one.
Now, back to topic. I believe you're wiring would be split. Meaning, you'd have wires from each pump going up to the switch. Maybe others will chime in to confirm.
