First De-Winterization
rmrstlmo
Member Posts: 237 ✭✭✭
This will be my 4th season owning my 340. I've always had the winterization and de-winterization performed by my marina. It doesn't look like the de-winterization will be that difficult so I'm going to give it a shot. As long as the weather still looks good I'll be heading to the lake this Friday. Wish me luck!
Ray
2006 390
Previous 2000 340
06 Rinker 270
My boat stays in the water year round. I appreciate any tips with this type of de-winterization. Should have put that in the original post.
One specific question I have: will seawater intake for the A/C unit need to be primed?
Ray
2006 390
Previous 2000 340
That will depend on how you "winterized" it. Up North we drain them and run antifreeze through them. Under those circumstances sometimes filling the strainer bowl with water in the Spring is all that is needed - sometimes loosening and tightening the bowl a few times while the pump is running will help with the prime - sometimes a run down the river/lake is all thatn is needed to prime the AC, in other cases back-priming the system using the front discharge hole (not the drain pan hole - DON'T confuse those two!!!!!) using a hose will initiate prime.
In my case with a 360 and its long supply hoses when I lost prime due to winterizing with anti freeze I had to force feed the system water, sometimes even taking the supply lines off the AC unit. that's why I added a pressuring valve to it.
Remember to check for leaks when you open the drain **** valve for your AC and generator (if you have one).
I'm ocd so I changed them often (too often) on older engines but the fogging oil probably have burned-off after the first decent run, anyway.
On newer engines the plugs have a variety of exotic multi-year coatings and it's a waste of money even for an ocd guy like me to replace them every year.
If in doubt we have a great spark plug chart on this forum that matches plug tip colors and deposits to spark plug and engine health or you can google it.....basically after a normal cruise your spark plug tips should be a light gray with few if any deposits.
BTW most marinas where I boat won't properly fog an engine any more for EPA reasons which IMO is a shame as "real" fogging was great for older engines.....AND there is literature that suggests "old style" fogging of engines with catalytic converters can damage the cats $$$$$$....so I respectfully suggest that you be careful!
