Power steering leak
planesailing
Member Posts: 173 ✭✭
i seam to be loosing power steering fluid as I'm having to fill the tank every couple of weeks but can't see any signs of a leak. Anybody got any idea where I could be loosing fluid? I have a 242 with merc 5.7 efi bravo 3.
If it gets pumped out, you would see it at your marina. A little bit of hydraulic fluid will cause a big (very big) slick. It likely won't all come out while you're cruising. What does your bildge water look like?
small pin hole behind the engine. It rubbed thru over the years. There is a metal clip holding the hose in place on the engine side.
i had to bend the clip and when i did that it started spraying like crazy.
long story short I had a leak but went thru heII trying to figure out where it was coming from. I was getting fluid in my bilge.
my guess it's either being pumped out or it's a such a small leak that it's collecting on the back side of the engine.
it also could be the cooler.
Cooler hoses swell up and leak or cooler itself is failing.
deoending if it's a single or a twin it's not bad a of job either way to change them.
2 small hoses
2 large hoses and clamp to undo.
