Got a question about the reciever on my truck
On my Ford Excursion has a class 3 rated hitch, 500 lb. tongue wt. capacity and 5000 lb. tow capacity. If you add weight distribution bars capacity doubles.
My new boat and trailer likely has a tongue Wt. at around 800 lbs. and a tow weight of around 9500 lbs. Looks like I need a class 4 hitch. Does anyone towing a 270 know their tongue wt. and tow weight?
Home port: Hammond Ind.
Best Answers
rowboat212
Member Posts: 74 ✭✭
Friend, get the class 4... That's a rating you need at least 10~15% minimum buffer as a minimum.... if youre near any elevation, I'd be looking at 25~30% buffer. -
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
If you are going to spend the money on a class 4 just get a class 5. I am surprised the excursion doesnt have that already. -
TikiHut2
Member Posts: 1,431 ✭✭✭✭✭
My '04 FV270 with tri-axle trailer packed for a weekend weighs in at 9500lbs +/-. I run my tongue wt at about 7-8% or about 750lbs. I wouldn't reccomend wt distribution bars for your boat trailer. Just get a serious hitch, good brakes, strap 'er down well and hit the road. My 2wd 6ltr Vortec 3/4 ton Sub w/xtra large trans cooler pulls like a rail at 65mph
Good luck. Mike
Post edited by TikiHut2 on2004 FV270, 300hp 5.7 350mag MPI Merc 305hrs, 2:20 Bravo3 OD w.22p props, 12v Lenco tabs, Kohler 5kw genset, A/C, etc.etc...Regular weekender, Trailer stored indoors, M/V TikiHut, Sarasota, Fl -
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Just remember the airbags are for 'leveling' and better ride, they do not increase load capacity. Weight on the axle does not change with an airbag addition. Using a weight distribution hitch does (when used correctly) lighten the rear axle load by shifting it to the front suspension/axle. Hitch up your trailer w/boat and head to a CAT scale, it will give you the loads per axle, try with and without the airbag inflated and it will not show a difference. Overloading your axle will be asking for trouble in the long term. Be safe!Past owner of a 2003 342FV
That said, I've never noticed a w-d hitch on a boat trailer but admittedly haven't been looking, though I tend to notice random things like that. Usually gawking at the boat, though! I don't see any reason it couldn't be used. Could be tricky mounting to an I-beam aluminum trailer.
I also agree with 212 and wouldn't use them as a crutch for capacity. I'd def want a hitch rated for the weight. Trailers coming loose are not a good thing! Seen it first hand- scary! (Fortunately not mine!)
What do you guys think about me towing my 2014 260 on a triple axle (electric brakes) with my new 2016 F150? It's a Lariat Super Crew 4x4, 3.5 ecoboost with "max trailer tow" package and the "good" rear end. It has every option though so it probably doesn't have the full 11,500lb tow rating.
I'm thinking of towing up to Charlevoix, MI (about 4 1/2 hours drive) for a week or two using my uncle's new trailer. I wonder how the radar guided cruise control and lane keeping assist would work. lol -=Mike G.
2014 Rinker 260EC
