Replacement gauges for dash matching for 342 Fiesta Vee 2004
I need to replace a tach and engine sync gauge anyone have any idea where you can get matching ones? and if not are they plug and play for the engine sync if i got one from Sierra for example?
vessel view would be nice but $$$$$$. What I used was around 260.00$ for the tach plus 50.00$ for the dual hourmeter. And it is also DIY.
Wild, the sync gauge is at the bottom gauge where the rectangle is the installation was quitte simple a few mod of the wiring harness and really good instructions provided the actual gauge diameter is smaller then the original Faria but I made a filler ring and it looks great
The gauge is really precise and you can adjust the sync by 50 RPM. On the original Faria the hours Meters was inside the Gauge, so I removed they Faria sync gauge and install a dual hour meter that you can see on the right of the rpm. The sync gauge plugs in the same way the old Faria did. Look at the Floscan.com site.
Here is the wiring mod that I did to installed it. If you need more info let me know
Paul
The sticker is a reminder of where to position the two controls so you could move the front or the back of boat in one direction or another using only the engines not the steering wheel.
Paul
The wiring diagram is from a Rinker 300 express 2007, maybe yours could be different. But that should not be a problem
For the Flowscan Twins tach go on there website you would have a choice of different color for the background,mine is white. The dual hourmeter was bought from perfprotech.com.
P/N #S67281P or Sierra P/N 67281. I am pretty sure that will work with your setup
Paul.
The people at Flowscan are really good with service don't hesitate to call them
