Needing throttle when engine is warm?Volvo 5.7 GI/E
could do with some advice on Volvo 5.7 GI/E needing throttle to start once warm?
engine starts from cold perfectly and runs fine with no issues. Today we went out to sea for about an hours cruise, switched off the engine for 30 mins or so and when I restarted I need to give her some throttle. Once started fine, no issues and cruised back to port. Once docked tried to restart and again needed a touch of throttle. Engine has been fully serviced with new leads, distributor cap, plugs, new manifolds and risers, water pump etc. All in tip top condition!
Any suggestions as to why I need throttle once warm? Any advice much appreciated
Russ
Russ
Until I learned this technique and I didn't give the starter extra time, if it failed to start on the third or fourth attempt I'd go to the "flooded" start technique, which is to push the shifter central button to disengage the transmission, move the throttle to the WOT position, start the engine, and when it fires up, shift back (quickly!) to the neutral position. I hope this makes sense.
Andy
I have had the same issue with my 350 and @andyd technique is the same I follow. I also make sure to give time for the pump to start before I turn over, waiting for beeping to stop after key is turned.
06 Rinker 270
Andy
