Another prop question
Just got a 212 captiva with 5.0L and alpha one drive. Had it out twice last fall and the boat ran at 5000 rpm and 52mph with a 21 pitch 3 blade prop. While the hole shot was fine for regular boating was a little lacking for skiing. Have contacted a reputable prop shop in Cincinnati, the only one. He recommends a four blade prop and gives me 2 choices. One four blade needs to drop the pitch to 19 to maintain overall performance. He claims for a little more money they have a Mercury four blade that will increase hole shot while maintaining wot performance and keep the pitch at 21. Assuming both of the above statements are true, my question is is their an advantage to staying at a 21 pitch vs the 19 pitch when changing over to a four blade. Appreciate any feedback I can get as I am ready to make the change, just want it to be the right one.
Best Answer
212rowboat
Member Posts: 2,593 ✭✭✭✭✭
there is a lot more to it than pitch, diameter, and number of blades... a prop with all those matching another may perform totally different than each other. you can remove some elements of the crap shoot and get somewhat close, but you can't get solid data until you run various examples on your own rig...
Dave
Came with aluminum 19p 14.5" three blade merchant prop. I let him try the pleasure five I run... We blew it out like it was nothing.. He's trying to stay away from wot until it's broken in with ten or so hours, so it's really hard to tell what it can or can't do, but the bow came WAY up and about 3/4 to plane the prop broke free and free spun until it bit again. Too much power and too much heft for that prop. Either that, or that Monterrey isn't much of a performer. I would never have guess that prop was so much different on a similar boat as mine- which just drives this point home about different boats, different props, different uses and different conditions making huge impacts...
I had a solas four blade in 23p I'm letting him have.. I forgot I had it. He went back out today with his pops... I'm interested to see how it performs with that prop... I'm also thinking I may be prop shopping soon...
