carbon monoxide goes off - could it be the flappers?
Brite Eyes
Member Posts: 5 ✭
We took our boat for a trip and sure enough the alarm went off again even with all the isenglass in the back down and the front center off. It was very bad to the point captain on board was affected and friend on board passed out. Had to shutdown for awhile to recover. Luckily we had oxygen on board to help.
A friend mentioned to have the Flappers checked out on the engines (merc 350) as they had a similar problem. Had a mechanic check at dock but couldnt smell anything. Still waiting patient ly for our mechanics to come, but probably will be another 3 weeks so asking everyone to gain knowledge. I know I posted something similar a month ago but I apologize I cant find the post on my tablet. The captain sent an email to Randy then as well and Randy requested our number to discuss but we are still waiting for his call.
As you can imagine I'm not comfortable taking her out anymore and we really like cruising. Next trip scheduled to Baltimore and Annapolis and would hate to miss it.
Any other suggestions appreciated. 2008 350 cruiser
WOW!! A person who passed out from CO was in need of medical treatment ASAP. Lucky for them to revive with no help.
I took the last CO post to heart and got serious about sealing the engine compartment and getting additional high quality CO monitor/detectors. I then put this Youtube video together two days before this very post to more easily show what I found. It seems eerily relevant to this most recent VERY close call.
(YOUTUBE LINK Pt1 and 2)
Man, That's a scary post. Hope others follow suit to see what they can do to prevent this from happening to them. Don't assume it won't happen to you. Check that firewall and update maintenance and warning systems as needed. Mike
Be safe, Mike
I forgot to mention that I tested my new CO detector(s) by holding it at the stern while the engine was running and it quickly registered. So I figured I'd test my smoke(s) too. Pressed the test button and alarm sounded fine, and I don't know why but I thought I'd also try a real smoke test too......which it failed miserably. Out it went.
Double check everything....
Talk about tricky.. but, here is the best trick I've ever discovered, Fwiw..
Ever heard of seafoam? I don't care to discuss its merits as a cleaner or tuning compound, because "who knows". There is good and bad in that capacity.. if you allow it to siphon into the intake manifold via a vacuum port, it will draw fast enough to induct it, and slow enough not to kill the engine, or hydrolock it..
Once its all in there, kill the engine and allow it to rest for about ten minutes..
It will smoke like a Hollywood smoke machine when you refire it.. it will also smoke where the leak exists, if in fact there is one..
BTW, there were flappers or shutters in my exhaust hoses past each riser (standard thru-drive exhaust).
Mark
2019 MTX20 Extreme
Interesting update. Mike
Former CO post (LINK)
