Windlass 320
I had a problem with my windlass on the weekend. When under load going up it cuts out I think the motor is shot. I have a 2005 320 that has a horizon 600/900 windlass. What would be a good replacement. Thanks, Pedro
Check you connections on the circuit breaker, they are known for vibrating loose and causing intermittent issues.
Becareful with the small gear on the motor. My worked fine on the bench, but would seize under load. After messing with it back and forth it would free up for a while then get stuck.
The switch is very easy to test, you just need a meter or test light. Pull the screws out and pull the switch out. You will see two sets of heavy wire, 2 reds 2 blacks. 1 set is the feed, it should have 12v without you pushing the switch. The other set will have 12v when you push the switch. It just reverses the polarity depending on which way you move the switch.
