8.1L 496 Starting issues
jbschmalz23
Member Posts: 219 ✭✭✭
I have the 496 engine in my 280EC. Starting at the end of the season last year, every once in a while, I would go to start the engine and it would just crank. Once was even after I had been out cruising for a little bit and we did some floating to eat some lunch.. went to start it and nothing. If you wait a little bit, and crank some more, it will eventually start. I saw on another forum to swap the relay on top of the engine for fuel with the trim relay, etc. Got the boat out of storage this weekend, it started right up with the muffs.. was idling for about 5 minutes and then quit, and wouldn't start again. I tried the swapping of relays... nothing.. anyone ever have this happen? This is my first fuel injected boat.. wasn't sure where to start?
it could certainly be a gummed up IAC... it could be a clogging fuel filter... it could be a blocked vent on your tank... it could be a weakening fuel pump... that's the order I would approach it...
get a fuel pressure gauge from the parts store... you should hold a steady pressure no matter the RPM's- so if it fluctuates more than 3 or 4 psi, you've got issues with the pump... if it steadily decreases, you've got a tank vent issue... if it holds steady throughout, you've got IAC or air filter issues... if it drops and then returns w/ more throttle, you've got fuel filter issues.
nope- OBDII reader will do you no good, has to be merc.. the ports won't even connect..
that TB has some build up on it, and it indicates to me the IAC is going to be filthy, too- it when that blade is closed, all that stuff is sucked through the IAC... I wager that is your issue after seeing the blades.
always be careful pushing things around in the IAC- the mapping is easy to toss on those things, and the PCM can be tricked.
that hole in the blade- it makes sense now, after reading your symptoms, that if that was the primary source of air for the engine at idle and because the IAC is obstructed, it would behave as you described. a 496 is a whole lot of engine to feed through a tiny passage........ I've never liked those ports- and certainly not using more than one (as the perforations allow you to knock out another) because it pushes the logic on the PCM to the outside parameters of it's air tuning mapping- which pushes other items to theirs as well- TPS's, fuel trim to account for more air, ect...
If it were me, and it isn't, but if it were- that TB would be on my bench tonight with the electronics carefully removed and getting blasted with TB cleaner- then put back together (it's not NEAR so difficult as a carb) with a cleaned or new IAC and gaskets... sparkling...
the IAC's position is 'supposed' to be known, and that known position allowing a certain volume of air past... no air, no run... meanwhile, that certain volume of air is sprayed with a catalyst (fuel) which allows it to be ignited at a controlled point- the injectors and fuel pressure regulate via logic on the PCM (reconciling IAC position, throttle position sensor info and mass of air flow (maf) or manifold absolute pressure (MAP) info) about how much fuel is to be sprayed, and in proportion to the amount of air ingested.... if the air is too much or too little, and the fuel too much or too little, which is easy to happen when one of the measures in place to meter it (your IAC), is misbehaving. = no start or hard start and poor running.
make sure and clean your flame arrestor too (air filter).
Here is the link to purchase the IAC:
https://www.rockauto.com/en/moreinfo.php?pk=1319722&cc=10001422&jnid=120&jpid=0
An idle air control actuator or idle air control valve (IAC actuator/valve) is a device commonly used in fuel-injected vehicles to control the engine's idling RPM. In carburetted vehicles a similar device known as an idle speed control actuator is used.
