Shore power only charging one bank
My 2000 fiesta vee has two battery banks. Each bank has two batteries. Last season the charger seemed to charge both sets of batteries fine. Went to run the boat in the drive on the hose today and noticed bank 2 was dead. It's the bank I left the switch on over the winter to maintain my fridge and such and I know it was working fine a few weeks ago. Moved the boat to a new house and it doesn't seem to be charging now. The other bank appears to be charging just fine. Any thoughts? Are there fuses that run between the charger and each bank individually? Any help is super appreciated!
@MarkB, I do not have an LCD screen.
Thanks for all of your help. Seems like every year when its time to get on the water things start to go wrong.
Not an expert there. I'd go to a local marine shop or West Marine and give them the batteries you have and current charger. Hopefully they would know enough about it.
Before you do that, are you sure all 4 batteries aren't shot? It's a possibility you should elliminate. If they are all shot, none of them would hold charge. I think the fact that the trickle charge was able to do the trick is a clue. I'd be tempted to trickle charge them up, and leave them unconnected for a day and then test voltage to make sure they are holding charge, that way you know it has to be the charger.
When you say AC plug, it is not a transformer is it, as in it converts to something like DC at a different voltage? I wouldn't think so, I'm assuming you are talking about a normal, plain plug, right?
If so, I can't think of a reason why you couldn't splice the 110V feed line. Cableguy Greg is probably the best guy to ask, but if it were my boat (don't take my advice, lol), I'd be tempted to do it with safe, to code splicing/connection. One thing you have to watch is connection that don't meet code = no insurance if something happens.
@randy56 its a 2000 model so 16 years is probably a good life span for a charger i would assume.
http://www.amazon.com/NOCO-GEN2-Waterproof-Battery-Charger/dp/B003JSJS5I
I like it it better than the original so far.
