Leaking shower and side vent weatherstripping
I have a 1992 Rinker Fiesta V 260 that I am quite proud of. Two things are bothering me.
1) I replaced my old shower sump pump with a new atwood and I still get a wet rug outside the shower door everytime someone showers. The pump works, but somehow the water is not being channeled correctly for the pump to suck it up. Any suggestions? As you may know, very cramped quarters to troubleshoot.
2) I want to replace the weatherstripping around the side vent windows (starting to dry crumble) I managed to remove the entire piece from the bottom on the starboard side and it is approx 5/8 x 1 5/8" What material is this specifically and where can I purchase replacement rolls of this weatherstripping?
Thanks in advance for any help.
Best Answer
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
The putty tape is butyl rubber tape. Great stuff!!Past owner of a 2003 342FV
Thanks. As far as the shower drain is concerned, it looks like the shower water is directed to a trough that leads to the pump that sits in a well. The drain water for some reason is not making it to the well. The atwood pump is supposed to suck the drain water out of the well.
I found the custom weatherstripping on www.taylormarine.com P/N 8351000.
