Rinker heater
minnesota
Member Posts: 67 ✭✭
Here in Ontario, I just splashed my boat for another season, spring has been a little strange and cooler this year. A quick question, am I suppose to see water discharge while the heater is on or that's only on the AC cycle. Thanks
2008 280 EC
Thanks all, where is this reversing valve that I can lightly tap on the 280.
There may be a schematic for your HVAC on "google" if one of the forum guys doesn't speak-up.
You will need to know the BTUs (capacity of your unit) to access the correct schematic.
You can often fine the location of the reversing valve, even if it's stuck, by having someone turn the breaker slowly off and on while the HVAC unit is set in heating mode. Even if the valve won't reverse it should make a clicking sound. That way you could fine it.
Even turning the unit off and on might flip the valve. These valves can get stuck temporarily which is usually no big deal. Steve (Handyman's 342) knows a lot about HVAC as do a couple of other guys so hopefully they'll join-in.
BTW, it is a good idea to cycle the HVAC from heating to cooling a couple of times during the summer, not just use the heat in the spring, the cooling in the summer and the heat again in the fall. Make it reverse back and forth a few times during the summer and that usually keeps the valve free moving.
.....actually the easiest way to prime your HVAV or Generator it is to install a valve to prime it. Costs about$30 and takes an hour start to finish. You can also use it to draw in anti freeze for the winter and water for the summer.
"Going for a ride" to prime the HVAC system on my 3014 EC 360 would not push water through it even at 45 MPH. It is a very long line all the way from the aft berth pump to the front of the bow berth HVAC unit location and has many inclines and declines along the way. Power priming was the only way to do it.
