06' 342 Toilet Pump Location?
Went to use the Jabsco Electric head for the first time and had no prime. Bled from through hull to inline filter, still no prime. Ended up using a garden hose to force the water to the head and voila, prime. All good. Question is this - Obviously the macerator is attached to the toilet, but there is a separate pump for filling the bowl with water. I can hear it behind the shower. Is there an easy way to get to it? Thanks!
BD that makes sence. I thought about pulling the shower shelf but it is caulked so I didnt want to pull unless I was confident in the pump being there. Will have a look. THANKS
Loose hose is so that you can winterize it....it bypasses the water tank
Hold on, which Jabsco electric head do you have? Did you get the conversion kit for the manual pumping head? If so the pump is actually right under the dial that you turn left and right to flush. The macerator is at the very bottom of that unit.
You should be able to follow your water line from the bowl to where the pump is.
At least on the 342..if you pull that shelf in the shower, you'll find both the shower sump and the mid-berth bilge pump discharge hoses do not have a 'loop' on either, thus water can backflow from those thru hulls. If you look at the height of both thru hulls to the water line you can easily see how running in bigger waves can cause a little problem. Ask me how I know. lol I added a section of tube to make a loop for each. Problem solved.
