vacuflush odor
I have a 2006 390 with a sealand vacuflush does anyone know does it have a filter on the pump tank all of a sudden getting odor
Get a big orange filter. Takes 20 minutes to install. You won't be sorry.
The holding tank has a vent hose to relieve pressure in the tank when you flush the head. It's a flexible hose, maybe 1" diameter, that goes from top of the holding tank to a vent fitting in the hull next to the pump-out fitting.
Your holding tank is on the port side in the engine room, right? Look for a flexible hose coming from the top.
I like @craigswardmb's fabrication and a coup[le of like ones other Rinker guys have posted.
Remember the Big Orange also has a vacuum relief safety valve built into it to help prevent tank damage from excessive vacuum at pump out time.
If you fabricate your own filter you can but a safety relief valve from Tank Saver for about $25. It is a 10 minute job to install one in your waste tank.
I had big Orange filters and relief valves too.
1- removed the domestic and literally cut it in half. Poured all nasty contents in to the dumpster including spongy media at each end.
2- removed all of the stickers on it, was essentially 2" Pvc pipe.
3- went to Walmart and bought a 9oz package of aquarium activated carbon and a 3 pack of blue scotch scrub pads.
4- went to lowes and bought male and female threaded screw ends for 2" pvc.
5- back at the boat I cut the scotch pads in to 2" circles and shoved them in to the ends of the filter. I went 2 ply on this at each end.
6- used pvc cement that I already had to install those threaded ends where I had cut my tube on half, now it screws together back in to one.
7- filled both sides with aquarium charcoal and screwed both sides together
voila, new filter for $13 that will be easily refillable for $9.
First, apologies. It's pretty hard to monitor a tank you can't see. I've been spoiled by the newer Rinkers and forget the challenges of some of the older boats.
First question: Have you viewed the modification some of the guys on the forum have made to visually check their tanks by installing a viewing port - IMO it's brilliant.
Second question: Would the new stick on tank senders that read the opaqueness of the tank (or lack of it LOL) work on your tank if you could get access to a side of it through an access hole?
Re: the safety vent. It is called a tank saver but I may have completely struck out with my advice to you today, sorry :-( ..... because you need access to the top of the tank to install one.
In a possibly futile attempt to revive some credibility, Big Orange (many posts on this forum) does make several odor filters, the big one does have a safety vent built into it and is easy to install and super easy to change the charcoal on. BTW I posted a discount coupon on the forum and each guy who has purchased one has passed his coupon on to the next guy.
Sorry for the lousy advice I hope to do better next time.
Note: I only needed ONE box of charcoal.
Diggin - NICE! Thats pretty much exactly what I did only I re-used my Saniguard rather than buy all new PVC. Glad it works for you.
BD and MT - I looked at the sender link BD sent and a light went off. I dont have a sender in the holding and water tanks, my boat has that "Sensa Tank II" system for both tanks which means as MT asked I have those stick on sensors at 1/3, 2/3 and Full. The water works and the holding tank shows 1/3 all the time. So I am hoping/praying that the system actually works and that my holding tank air vent being completely shut off until now is why it only shows 1/3. Perhaps the lack of air flow was really only allowing me to suck out so much at pump out. This all started because of waste backing up in the bowl AND up the pump out tube... a symptom of a bad vent. Also I had a bad joker which I just replaced. Not only was my vent filter shot, but there was a major kink in the vent hose. When I un kinked I could hear air rushing. I cut out the kink and added an elbow fitting.
BD - I know of the inspection port in the far aft corner of the L shaped port cockpit seat but it sounds like there are 2 ports? One for fuel sender and one for waste? I'll check that out, at the very least maybe I can see how full the tank is from there.
THANKS!!!!!
If you have the sensa tank "stick on sensors" two of mine failed at 3 months use. (new boat)
We added new ones then one failed on the other tank. I think they may be cheap offshore cr*p. (We need to get manufacturing back to USA/Canada!!!!!) Good news - when the sensors work they're great.
While replacing the sensors for both tanks I noticed one of the attachment harness clips was damaged. It look like it had been forced at installation time or stepped on by someone. We replaced that too. After that NO problems!
