Duo-prop v. single
Looking at 2 identical boats (29' 10' 6" beam), ea with 2, VP 5.0 GXi motors, one has Duo props & the other has single 3 blade (not sure of size or pitch) props. Looking at the spec sheet the twin props offer about a 3 mph increase at same fuel consumption.
The boat with dual props is about $12k more and most other criteria between the two are similar. Are there any other significant pros/cons to one or the other & is it worth the extra $ for the duo props?
IMO the duo props are worth the money for the performance they will deliver, particularly if the boat is loaded-up. The 5.0 is, IMO, a small, small block and the Bllls will add needed performance. I can not be more specific about performance as I do not know the make and model of the boat you are considering.
.....and then there's re-sale some day. Buyers are starting to expect counter rotating drives.
For $12k difference, depending on what the single prop drive is (B-2?), you can change out the lower unit and replace with a counter rotating drive. I know on my B-2 drives (single prop), you can change the lower unit and make them B-3s.
@MT, it all depends on the boat. The larger boats tend to go much better with a single prop. It's mainly because that single prop is much larger in diameter. Mine goes like a dream with the single props.
