Generator into shore power?
russellh
Member Posts: 155 ✭✭
Am I right in thinking I can run my Honda EU20 Generator direct into my shore power socket on the boat? Would have a lead made up.
Anyone else done this?
I've seen it done a number of times. Just need to take the normal precautions of running a portable unit (ie, not inside the boat).
yes people do this.
Is this the correct cable to get?
Marinco Marine Electrical Shore Power Pigtail Adapter, Yellow https://www.amazon.com/dp/B000NHZV54/ref=cm_sw_r_cp_tai_zKKpxbECADQBG
The Marinco I saw used for this application was called a Dock Side 15A to a Boat Side 30A
I believe the Marinco number was PC15-30. It should cost about $80.
If you have any doubts I have spoken with Marinco personnel in the past and they were super!
Okay, I just looked at your link. I believe what your link shows is correct, but - it is a much older version. I would spend the extra $30 and get the new EEL version as it lights-up to show proper connectivity and is a LOT easier to use.
