Galley pump runs ONLY when water heater on?!?!
Okay, here's a weird one that I just can't figure out:
My galley pump will come on in short bursts or pulses(almost like there was a leak or a faucet slightly open) ONLY when we have the breaker on for the water heater. There are no leaks in the system, the water heater drain is shut tight and the bypass is closed. It doesn't happen immediately, only after a few hours of the breaker being on.
More info: 2002 FV270, all faucets are shut tight(galley sink, bathroom sink, cockpit sink and transom shower), brand new galley pump installed last year(because I had this problem and thought that was the solution).
Ideas: are there back flow valves on the lines leaving the water heater? Could that be it? Any other ideas
I suspect you have power and this is simply related to the water getting hot and you have a blockage somewhere in the lines.
Check strainer, and follow lines as much as you can to determine what shape they're in. There's a non return valve to check as well and inspect the faucet, they have a strainer on the end as well.
Yes I'm talking about the diffusers.
Note that when you start your boat after winterization this tank will be full of air and should be releaved through the safety valve to get rid of all air.
