Need a Measurement for radar arch bimini tracks 2000 FV310
JstewJstew Member Posts: 65 ✭✭
I'm ordering from TJ (@boattech01) replacement bimini tracks for both the front and back of the radar arch on my 2000 FV310.  The problem is that the boat is 3 hours away and I don't have the measurement. They come in 16 ft sections, so I'm guessing 2 of them should be plenty.  If anyone can point me to where I can find such measurements (or better yet, if you happen to be on your FV310 with a tape measure :smiley: ) I would greatly appreciate it!
John E.
  • summerxsummerx Member Posts: 211 ✭✭✭
    I'll be out this weekend and can get them then.  I was thinking about doing this on mine as well, but it seems like it will be a PITA to do?
    I changed the tracks on my previous boat (2001 310) years ago. It was time consuming because there are a million little screws but it wasn't overly difficult. Hardest part was bending the track around the turns but one screw at a time and they bend. New tracks are new and full of plasticizer and bend much nicer than your old, dried out tracks. I used a clear silicone sealant all the way around so that it looked clean and was easy to clean up, not sure that is the "right" sealant though. 16' sounds like it will barely make it. I remember buying 3 pieces - two longer and one shorter. You should confirm before you order. Good luck!
  • JstewJstew Member Posts: 65 ✭✭
     Thanks guys. Also, on another thread it was suggested to use a heat gun on the bends
