390 rinker 8.1 volvo oil backpressure
I have a 2006 390 with 8.1 Volvo osi bought new. This year when I put it in the water I started getting oil in the bilge. Upon investigating with only 600 hours I saw it was coming out the dipstick. oil pressure is same as other engine no loss of power. Manual says no PVC valve how does it handle back pressure. Any help would be nice
do a compression check, an see if 1 cyl is down on compression and you are getting serious blow by.
check to make sure dip stick is engaged correctly and that its not loose.
check your valve cover breathers and see if they are pissing oil as well.
as above... check head gasket as last resort...
check oil , if its milky brown or not...for water contamination or coolent
there are some things that don't make sense. if you had a gross leak of pressure, you'd certainly notice it. you said there is no loss of power... the engine produces by-pass gasses, as any engine does- it's not back pressure... that's something altogether different... bypass is gasses slipping past rings and pressurizing the crank case... if you see oil frothing, it's most likely overfilled or there is substantial by pass- if there is that much by pass, there is something wrong to the point you'd feel loss of power...
do this... take your oil fill cap off and fire the engine... rest the cap on the tower but don't thread it... is there enough bypass to push the cap off? if there is, there is an issue- if there isn't, there most likely isn't an issue.
my guess is you're overfilled and just don't know it... it's way to easy to do and everyone has likely done it whether they realize it or not... it doesn't take much to reach the windsor tray, and when that happens and the oil is being slapped about, there just ain't no tellin' where it will go...
when ever you get pressurization like that its a good sign you are getting blow by.
When I was using high power turbo engines, when we saw crankcase pressurization it was a sure sign that some sort of blow by was happening, its never a good sign.
And on the cheap low powered NA engines..I would run them until they balled up. And I actually mean balled up, as in the pistons would be balls of metal at the end
this is also a time to upgrade to a better engine..or perhaps engines
since you should 100% check the other engines compression as well while you are at it.
