battery condition indicator.
MIKES342
Member Posts: 182 ✭✭✭
My dock in central Ohio dosen't have electricity so I ordered a generator for my 260 when I purchaed it . I haven't used my fridge becasue I am afraid I will run the batteries down although I would like to have it working on the days I go out. With that being said does anyone have any idea how long the fridge willwork before the battery needs charged by the genny. Also is there a battery condition indicator anyone could recommend
MT and BD are both add some great input. The sailing guys who cruise consistently usually anchoring out for weeks at a time have been all the way around marine solar panel system design. As much as solar technology has improved it's still pretty tough to keep up with the fairly heavy use of refrigeration with solar. Simply moving a panel slightly askew from an ideal angle, or a partial shadow from rigging stifles panel efficiency pretty dramatically. Reducing your load as MT explained is a huge help. Choosing high efficiency panels and using a controller to manage charging are a must and an education in themselves.
Do a search on some of the sailing/cruising forums to find some helpful spreadsheets to effectively calculate your demand so you better understand how to design a system and choose controllers, storage batteries and panels to fit your needs. If you're doing long weekends It's almost more practical to just use a small genset like MT explained. If you don't have power otherwise and have a dock side solar array for maintaining your batts and frig it'll be far easier and you won't have to figure out on-board mounting or storage challenges.
All that said, Here's a link to a good run down on your monitor question and slew of other marine challenges spelled out by an OCD rag boat guy that I've been reading for years. Hope that's helpful. Good luck, Mike
(LINK)
I appreciate all the information. I do have a marine genny installed and live 5 miles from the marina. We do not have shore power at the marina and I do run the genny sometimes when we just go and sit on the boat probably 4 nights a week. The consumption of gas is about 3 gallons per hour if I read the specs correctly.
If I could use the fridge overnight say 10 hours and then charge it up withthe genny the next moring that would be sufficient. The reason for the battery meter was just to try and make sure I knew at what state the battery was in. Charged, half charged or needs charged. I guess I just need to try it. I guess since my genny is connected to 1 battery it should start the genny then I could start the engine in the worst case senario.
Well I guess it is time to try.
Once again thanks for all the information.
