Kohler 5E Routine Service Question
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
Bought the boat in May and plan to just do routine service to my 5E this weekend. I have ran it every other week, runs fine and pumps plenty of water, just want to get service up to date. 2006 5E that has 222 hours on it. I plan to change plugs (NKG 4ES), exchanger anode, oil (SAE 30), oil filter (Sierra 23-7821) in line fuel filter and twist on fuel water separator. I assume I'll have to take off the entire sound shield and I've got a 2ish hour job.
Question on the in line fuel/water separator. It is a Quicksilver 35-802893Q01 spin on. Do I need to fill the new filter with fresh fuel and then spin it on to prevent a large air gap? Thanks!
@Liberty44140...I know you know this but just running the generator isn't enough to keep it healthy. It has to be run under load. Heating water in the microwave and/or running the HVAC is good. When you run it under load you work the motor and the generator. Under electrical load the generator windings heat-up which removes corrosive moisture, particularly in salt water environments.
I think it is 1.44Qts oil w/filter. I run a straight 30W synthetic and a NAPA XP oil filter.
thanks Ras.
Guys- I had a new in line filter that I bought 4 years ago for a previous Kohler 5e and the nipple fitting would not thread in to it. Are there different in line filters for the 5e? I'm taking about the filter that is just under the electrical box in the generator. Had to remove 2 screws to get to it. Would still like to change it as it is original but I ended up putting it back in for now.
Question 1- is this the right fitting to bypass the filter that screws in to the fuel pump? Looks right - https://www.amazon.com/Anderson-Metals-57001-Fitting-Connector/dp/B00F68TAV6
Question 2 - here is the fuel filter that I have (and I just replaced the filter last Fri). Looks to be both fuel/water separator and a 25 micron fuel filter. This filter is mounted to the wall just after the generator fuel shut off valve.. Line goes from this filter, to the Inline filter attached to the fuel pump (which I now plan to remove):
