Changing Merc 350 Raw Water Intake Hoses
Liberty44140Liberty44140 Member Posts: 4,409 ✭✭✭✭✭
edited June 2016 in Engine Discussions
My boat is 10 years old and the hoses from the thru-hull intakes are showing some stress cracking. Need to change. Both of my engines have 2 water intakes. Raw water comes in through BOTH the Bravo 3 intakes and through hull intakes. They Y together and then go to a strainer on each side. The lines from the strainers to the water pumps are fine and from what I can see the lines from the I/O to the Y are fine. I am just changing lines from the through hulls to the Y to the Strainers (at this point). Questions:
1 - The hoses say "HARDWALL 100-1140 1 1/4" ID" on them. I plan to replace with the exact same hose, found it online for about $6 per foot. Also will get some extra hose clamps. Is this still a good hose to use?
2 - My largest concern with this project is getting the hoses off of the fittings and then getting the new hose on the fittings. Any mechanics tricks to hose removal and re insertion? Heat gun, dremmel wheel to cut the old off?
3 - Is there a lubricant or sealant I should use to reinstall the hoses?
THANKS!!! Pat
