Trim Limit Switch Adjustment?
212rowboat212rowboat Member Posts: 2,593 ✭✭✭✭✭
Not the sender- that was not tricky at all, but the limit switch...
alpha one gen two...
How do you do it?  I've read it is done by measurement of the rams, and after raising it from fully down- but..... yeah, that didn't work... I have to use my tilt (trailer) to get my trim to full on plane position... I can make it work- I trust myself enough, but what if someone else is at the helm and relying on that gauge?  I don't wan't someone to go north of trim and into tilt while the boat is underway...
so...
how do you guys adjust the trim limit sensor?
