342 Engine Hatch issues
Having issues with engine hatch motor. I can use the emergency posts and it opens fine. When I use the switch at the helm it is very slow or does not open the hatch. Almost like not enough juice to open it. Looked at wiring diagram and doesn't appear to be anything between stitch and motor. Any thoughts on what could be the problem? The switch?
If the actuator works fine when you apply voltage to the by-pass posts, but operates slowly when operated with the switch on the instrument panel you likely have a voltage drop issue in the feed circuit to the instrument panel actuator switch, across the switch itself, or high resistance in the ground circuit.
On my 2009 320 Rinker placed inline bus-bar type fuses for the 12 volt circuits to the Instrument panel low enough in the bilge that they can come in contact with moisture causing corrosion and voltage drop to the helm. I'm not sure about the wiring on a 342 because I've never worked on one , but you may have a similar problem.
Recently had an issue with the hatch on my 350. It would work fine sometimes, other times it would not open or if opened would not close. Traced the problem to a set of Relays located behind the electric panel topside. Set of 5 relays were all badly corroded, only 2 were connected to the hatch. I replaced all 5. The hatch has worked perfect since then. I do not know what the other 3 relays are connected to.
