Fridge Question - 110V to 12VDC
OK guys, my fridge down below in my 280 worked fine last year both shore power and 12VDC. I have noticed this year it will only work when connected to shore power and not on 12V but my cockpit fridge stills runs on both just fine. Is there a module or controller of some sort on the fridge that allows it to run on 12VDC? I am just curious as to where I should start my troubleshooting. Thanks fellas
Boat Name: Knot A Worry
Could be a blessing in disguise. The prior owner of my boat put in a converter so that the cabin fridge runs only when connected to shore power. I suspect this was the result of several dead batteries from running the fridge while away from the dock. I have considered changing it back. In the meantime I keep the freezer filled with cold packs which helps keep things cool after unplugging. The only minor annoyance is the small amount of freezer ice melt that leaves a puddle in the fridge.
http://www.dometic.com/QBankFiles3/EPiServer/Dometic/US/Manuals/Marine-manuals/Refrigeration/CR-Refrigerators-Freezers-Manual_5525.pdf
The part number looks to be 101N0500. Not a cheap little part. There also is a light sequence to see what it going on.
I just found out that my galley fridge is a WAECO CR-0065. This model has a control module number 101N0220. That module has an external AC/DC module which is a Mobitronic MPS-35 switching power supply.
