Ski Locker Filling up with Water
I have a 2003 Flotilla, for some reason when any water gets in the boat, or if I run the pool in the front the water does not drain to the back bilge, it fills up the ski locker. there must be some blockage, It seems to stop at the gas tank. I have to suck it out with vac. I try to run wire down through ski hole but no help. Is there way to run cable from the back drain?
