342 breakers
anyone ever have to replace a breaker on the main AC panel? Where do you get replacements?
Total pita getting the panel out. Not enough wire on the input side to slide it out.
battery charger
portable fan
ice maker (hoping just a relay)
The breaker for the battery charger would trip as soon as turned on. Which is not bad unto itself, but I could see a flash from inside when it tripped (not a good sign) and the 'on' side looked like it got hot. Didn't smell bad when I got it out, checks ok with a multimeter. Not worth the chance based on the sparking and a new $500 battery charger.
I'll be splicing in a12" piece to the AC input wire too. So tight the panel would move maybe 3" out.
For anyone interested, I did find LED replacement bulbs for the panel. Might be a winter project.
Where did you find the bulbs. Been thinking of doing mine.
These are the breaker model/brand.
Light bulb model:
5312V1CP They are GM Dashboard lights. You can find 20 pack LED replacements on Ebay
