First long tow
                    well, I am planning my first long towing trip with my 270. I have only towed my boat back and forth from the the marina one or twice a year. But I plan on towing it about 800 miles one way to enjoy Geers Fairy down in Arkansas.
My tow vichical is an F350 dully so I should be good.
Just looking for some advice.
Trailer is in great shape everything on it is new. But still a little nervous. Any advice is welcome.
Home port: Hammond Ind.
that^, and- if you cover the boat, don't rely on snaps... tie it down..
oh... and grease the ball and socket... a lot of people don't do that...
As I am bit over legal width and not carrying permits, I hope these measures help convice the police that I am a safe driver and they wait for the next less-safe driver. Good luck, all good advice from other posters.
When I tow my 320 here's my list:
1) I have two spare tires / rims - just in case.
2) Aluminium high lift floor jack - very handy for changing flats and very handy when hooking and unhooking the trailer from the tow vehicle and you can actually move the trailer with the boat on it around a bit to align the trailer tounge and tow ball.
3) If you've never changed a flat on a multi-axle trailer, you probably don't realize that once a tire fails on a trailer, it most likely shreds itself to pieces at 60 mph. Once the tire shreds, you may not be able to break the torque on the lug nuts since the failed tire will not be resting on the ground. The non-failed tire will support the boat / trailer and the failed tire will simply spin when you try to remove the lug nuts. That's where having various 2x4 and 2x6 lengths of wood come in very handy - you can lift the trailer high enough with the floor Jack to place multiple pieces of wood under the failed tire if needed to get the lug nuts off. The lengths of wood also come in very handy for blocking the trailer to keep it from rolling. The wood blocks also come in very handy if your tow vehicle has a high hitch - the floor Jack may not have enough lift to get the trailer tounge higher than the tow ball.
3) tools - you can never carry enough tools. At a minimum, you want to have a tire iron with the correct lug size usually 3/4 or 13/16 lug nuts. I carry one of the tee handle types that has the 4 different lug sizes built in - you can get much better torque using the tee handle. I also check every nut/bolt combo on the trailer - suspension, bunks , wheels, etc. prior to towing. Check lug nuts multiple times.
4) Some flat fixer, a good 12v air compressor and a good tire pressure gauge. If you do happen to find a low tire, the faster you can get it aired up the less likely it will severely fail - heat build up with low air pressure tires will destroy them very quickly.
5) I also use a bow / front cleat tie downs to prevent the bow from moving up / down while towing on less than stellar roads. You get the bow oscilliating and you can get into trouble in a hurry. I don't draw the tie downs super tight - just enough to keep the bow on the bow roller.
6) Grease / grease gun. Consider getting a spare hub / seal / bearing setup just in case.
All of the above, I've learned the hard way of what happens if you are not prepared :-)
and Al:
I shot the sheriff (but I did not shoot the deputy).... I swear it was in self defense... he tried to shoot me down... so I shot him... I shot him down.... (thank me later when that song has been stuck in your head for days)...
DON'T USE THAT THING I LINKED!!!!! it sure looks cool, but it will break your heart and possibly your legs....
and Al, I DIDN'T shoot the sheriff... (but i may have shot the deputy)
Most of the trip is in Alabama. While coming back down last year, we stopped for the night at a hotel, parked the truck and boat out front as the desk clerk said she would be there all night. Long story short, the boat was robbed, removed all my electronics, stereo, speakers, fishing gear, etc..etc..over $5000 worth. When the police arrived, I figured I would get a ticket for being too wide, locals first, then sheriff and finally state trooper showed up. Not ONE of those fine law enforcement officers found any need to even question the width or height of my boat. Most of them even said, "nice boat".
I don't think width permits were originally designed for the owner/operator moving his own equipment down the road, they were designed for commercial drivers (and filling the gov't coffers) moving someone else's equipment. Somehow, owner/operators got caught up in this scheme and nobody has bothered to fix the error.
06 Rinker 270
