"House Charging" breaker keeps tripping above 1000 rpm
Hi Everyone,
I have a weird problem. 2007 Rinker 350 EC, MAG350s. For some reason, when I am running over 1000rpm or just about anything above idle, my "house charging" breaker trips. The breaker is located in the main rear DC panel area near the swim platform. I was cruising around last weekend and suddenly my radio started cutting out and my garmin shutdown. I plugged in my little DC power meter into the cigarette lighter and it read like 10.9V. After investigating, I noticed the "house charging" breaker was tripped. I reset it and the alternators brought the voltage up to around 12.4V at idle. When I started to increase the throttle, the voltage increased to around 13.2v which is about normal for my boat when I am cruising through no wake zones around at 1200rpm, then I heard a "click" from the rear panel and the breaker had tripped again. I haven't changed anything, and it was running fine all year. It is still running great but I can't really charge my boat from the alternators anymore. Not even sure where to start with this one, hope you guys have some ideas.
Thanks in advance!
Thanks in advance!
Was the generator running?
