Magnesium anodes in salt water
I checked the archives but did not see a spot-on answer. I have a freshwater runabout that I assume has magnesium anodes (installed by previous owner). They are in good shape. I will be in the Florida Keys next month for 2 weeks (hurricanes not withstanding) and the boat will be in the water the entire time. I have done this several times before and not given much thought to mags in salt water. I don't care if they deteriorate faster than in fresh water circumstances. Looking for opinions on whether I should switch to zinc for 2 weeks or just accept that they will wear out sooner. Anyone else see fault with this approach? Thanks! -Paul
"Additionally, the high rate of electrons served up by magnesium can create too much current — i.e., “overprotect” — when used to protect a metal that itself is already very active, like aluminum, especially one used in waters that are more conductive of electricity. This means salt water and polluted fresh water. In fact, if you take a freshwater boat protected by magnesium anodes to the coast and put it in a slip for a week, you’ll have a catastrophe on your hands."
http://www.boatingmag.com/how-to/choosing-right-sacrificial-anode
Looks like you should change the anodes.
Do you keep your boat on a trailer or in the water?
