cracked block
88_rinker_v170
Member Posts: 22 ✭
I have an 88 v170 the 3.0 that was originally in it had a cracked block beyond repair so I found a 2.5 out of a junk boat we had and I pulled it out and before dropping it in my boat I put it on the stand and planned on putting a gasket kit on it rebuilding the carb and just freshen it up. I drained the oil and as soon as I saw the milkshake my stomach dropped. I pulled the manifold and no crack at all I pulled the head no crack at all I stripped all the paint off the block and no crack the cylinders all looked great same with the pistons. The crank some how was clean as well. So I dumped a gasket kit in it and dummped about 5 qts of used oil in it and let it drain just to flush everything out then I added my fresh oil and filter. And it turns over by hand freely. What would cause milky oil in this situation? Am I safe to finish my project or should I just find a new engine?
Dont go down in size on the engine, you will regret it
