Light bulb
aero3113
Member Posts: 9,636 ✭✭✭✭✭
I'm looking to replace my cockpit light bulbs with LED. Does anyone know what the part number is of the original? Any recommendations of a good LED bulb? Would like more of a white light than blue. Thanks!
That's a 194
http://www.itc-marine.com/product/168-wedge-base-style-led-replacement-bulb/
http://www.replacementboatparts.com/whiteoblongcourtesylight.aspx
I put these in my 342 (blue ones).
http://www.apexlighting.com/boat-lights/courtesy-lights/montauk-led-12v/
For the cockpit lights, these are about as drop in as you can get, totally sealed, never water issues again. Look great too and bright. I have the blue ones installed.
I replaced the whole fixture on mine, same light. About 98% drop in, depending on the hole drilled by Rinker, at worst I had to caulk a bit at the edges.
The big issue with just replacing the bulb with an LED is the light lens is not meant for LED's, yeah a bit picky but it makes a difference. Plus you can still get water intrusion issues.
I used these:
Sealed. Drop in replacement.
I used these;
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=LEDwholesalers+G4+Base+Side-Pin+Disc+Type+LED+Bulb+with+9xSMD2835+12V+AC/DC+(6-Pack),+Warm+White,+1106WWx6+
http://www.amazon.com/gp/product/B00IS37G2Q/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
The above bulbs are discontinued. These appear to be the same bulb.
https://www.amazon.com/Ledwholesalers-Holagen-Replacemnt-Camper-Trailer/dp/B002Q9B1ZQ/ref=pd_sim_60_4?ie=UTF8&dpID=41kUkomoqNL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&psc=1&refRID=335AGG1XKXT8BBFF1BZY
