warning signal
dhopplesrdhopplesr Member Posts: 10
The warning signal comes on and stays on until the boat is shut down after about 15 minutes of running. All gauges are good and all fluid levels are fine...anyone have this problem occur?  Does not happen everytime
    When was the last time you change water pump impeller? Could be a water pump pressure problem.
  • 99270fv99270fv Member Posts: 94 ✭✭
    is it the motor warning system or could it be the depth finder with a false shallow or deep water alarm. my depth finder would do it on occasion and I would immediately reduce throttle thinking it was the motor
