Fingers crossed!!
my one vacation a year is Norris lake in Tennessee for a full week. Third day here and I Developed a knocking noise coming from the rear of my engine and I really hope its just the coupler. Does not seem to be there while at idle but just a little bit of throttle and it makes itself known. Hope I didnt spin a bearing but either way the engine has to come out. Not much room in the bilge on an 06 250 to pull it forward and check coupler. Oh well, all part of boating right!!
check the coupler is well greased and there is nothing that has fallen into the little gap between the actual coupler shaft and housing... I actually found a lost socket in mine that was making a heckuva noise, and was lucky it didn't snap the grease zerk off....
also, though, and for what it's worth... sound can travel right up that shaft and make an issue with the outdrive sound like it's originating in the engine (especially the back of the engine)... the shaft turns all the way into the bottom of the upper while in neutral, so anything in the upper can make that sound... so can a slightly stretched shifter cable that is trying to drop the drive into gear (either side, forward or reverse depending if kinked or stretched)... makes a terrible knocking sound...
if you're pushing 40psi @ WOT, you're okay... on an SBC/BBC @ operating temperature, pushing 10@idle is good enough.
back to his issue: I've not heard of a coupler knocking... it could, I guess, but in my opinion it's more likely in the upper drive- or, the cable is hanging between gears in neutral (which would be stupid simple to test by seeing if the knocking disappears while idling in forward or reverse)... if this were me, I'd pull the vent plug (on the upper) and see if the magnet has any metal chunkage on it.
Don't get me wrong, I'd just about rather do a coupler... if you have the facility, drive off engine out coupler swapped alignment drive back on is simple and maybe three hours... pulling the intake and replacing lifters is about four, and it's Hella messier.
It will be apparent if you pop the covers and peek.
About your shifter cable... was it oe or aftermarket? The Chinese have an aversion with pre-stretching cables, is why I ask.
for the feet, I ran a 14' 2x8 flat, and one on it's side, along with 45* supports on either side of the posts...
I ran a winch, attached by throwing a chain around the top of the beam and kept in place by taking two stacked 2x8x3's across the center....
the whole thing took about two hours to make, and it'll hold a lot more than the wimpy 5/16's cable strung through that winch (ran double to increase capacity).... that is my only concern about this thing- If that thing hangs around (i've buddies who are all about using it- one for his outboard, another for his car) I'll restring that winch with 3/8's inch cable....
it's freakin' nice to have my own facility. I can take my time with projects and do them right instead of relying on others schedules and/or renting a booth and trying to do it all at once.
