In search of Anchoring advise
this weekend I chose to anchor in the river to hear a concert and hang out. Tide was going out and I was bow against the tide, 49ft deep. . I tried to set a few times with no luck. I finally had some luck and set. It seems I wasn't letting enough rhode out. Any tips on knowing how much anchor line is leaving the windlass? I tried counting seconds(while pressing the windlass toggle switch) figuring each second was 2ft. Is there some type of indicator I can attach? Or any tips you have that may help?
Up n down 6 times trying to set I was worried about the windlass motor burning up ...plus I looked like a chooch.
A good secure anchoring is 10 to 1 20 feet of water equal 200 feet of rode a lunch hook
5 to 1 or a bit less. In 49 feet like you said let everything out but you need to watch.Another solution would be to go will all chain wich is probably the best and secure way.
Paul
http://www.westmarine.com/buy/west-marine--anchor-rode-markers--104372
Anchoring in 49 feet of water is going to be difficult unless you have a lot of chain.
