Stbd and port blowers
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
I noticed that when I run the blower switch at the panel for my generator it only runs the starboard blower, not the port blower. Odd because the generator is on the port side. When I switch on the blower switch at the helm both sides blowers come on but the starboard output air is much stronger than the port. Does this make sense? Port seems to put out a fine amount of air bit half as strong as the starboard.
Just a guess.... if the blower wiring from the generator switch was undersized then there would be a higher voltage drop to the blower (but this seems unlikely). Perhaps there is a resistor in series in the generator supply line to intentionally reduce the blower speed and extend the blower life. Adding the second supply in parallel (from the helm switch) would lower the voltage drop and increase the blower speed.
