Radioactive water
I will admit I have not been using my fresh water system like I should. Last time I went to use it the heat exchanger went on me. Instead of fixing all the small stuff, I have been using the boat. There...that's my excuse for lack of use so now onto the issue.
Backstory:
Last winter I took the fresh water tank home and cleaned it out real good. No antifreeze in system, except for maybe hot water heater. Beginning of the season I hook everything back up and run a full tank through everything. Hot water tank goes, I deal with making engine work and forget about it until now.
I turn on cockpit sink without the pump on and sink is flowing like never before but foamy and horrible smell. I figure this water is coming from hot water tank. Where else would it come from? I don't think it can come from tank without pump on correct?
Anyways I fill up tank and turn systems on. Super foamy, pinkish foul smell. My carbon monoxide alarm starts blaring and reading over 600ppm. What the heck? Each new tank of fresh water the ppm goes down. On my third tank and bathroom sink is still reading levels. Please explain this to me.
I havnt put in bleach for fear of exploding or causing a chemical reaction. Joke but kinda not.
Thanks in advance for the help.
update: 4th tank of water and head sink is reading 102ppm then goes away. At the end of the tank I am getting the foam back and the smell. Not as bad but still smell it. It's as if once the tank is done its pulling water from somewhere else. The hot water heater? Maybe I just need to remove that thing completely and replace.
Backstory:
Patrick
06 Rinker 270
06 Rinker 270
Worse case is exhaust leaking into the coolant system.
Worse case. How would exhaust leak into the water system? I am raw water cooled.
thsnks @Black_Diamond
06 Rinker 270
We overnite about every other weekend and take showers, We boat every week end, but when we skip a week without using hot water and it sets in there, it stinks! in two weeks, leaving hot water off during that time. So I flush hot water tank with new water, and stink goes away. After stink goes away then I turn on water heater. only takes 30 minutes and your ready for shower. Then turn off hot water heater the next day and its off again for two weeks.
This is all happening while on shore power.
Not using hot water.
After 10 flushed, one with bleach and one with finger I have clean water.
BUT I still get stinky water at the begging of turning the faucet on and at the end of a tank of fresh water.
Bottom line...I am getting contaminated water from somewhere.
@Michael T hot water tank is fu$&ed and needs to be replaced. I'm sure anode is shot.
06 Rinker 270
Does the fresh water still run through the hot water tank? Is there a way to bypass it?
@randy56 I'm not sure I should have checked that. I had both sides open to flush the tanks. I will try. However his was happening also at the cockpit sink which I believe can just run cold since it has one knob.
I think I have clean water now but still makes me nervous. I am going to remove the hot water tank completely and get rid of it. Will I need to reconnect lines in some way without the hot water heater?
06 Rinker 270
Good point about 15 gallons, I was filling it up completely. Quite a process.
I will say I used it all this weekend and it was great.
06 Rinker 270
How do you bypass it?
06 Rinker 270
Here is a link to a place that sells them. Part number 88-9283.
http://www.pplmotorhomes.com/parts/rv-pumps-water/flair-it-fittings.htm
Ill have to check on the hot side. Do you have to winterize them independently from the two valves?
06 Rinker 270
The PO probably used it to winterize without dumping into the holding tank.
Is the drain for the hot water tank the grey knob on the front of the unit?
06 Rinker 270
Thanks for the help John.
06 Rinker 270
