Fresh / Black Water video Monitors
Last year I put new tank sensors on the fresh and black water tanks. Towards the end of the year, it appeared that they were acting up so I'm not taking any chances. After removal of panels to get access to the tanks, I mounted a vehicle wireless backup camera
I then put an LED light and mounted it to the top of the tank
This will all feed into this monitor which will be mounted in the aft cabin.
Once everything is all set, I'll have a switch that will turn everything on and I'll be able to monitor my tanks. I'll keep you all posted as I progress with this project.
That's what these forums are all about.....:-))
https://rinkerboats.vanillaforums.com/discussion/5826/342-waste-water-tank-view#latest
- I had a couple of extra spreader lights hanging around from coastalnightlights.com. I silicone'd them to the top of the tank.
- A couple of back-up cameras from ebay
- A 2 channel video monitor
- Rocker switch with LED. That one switch turns everything on.
Tear aft cabin apart, put a line with a marker about 1/4 empty on water tank, mount camera low to see the line. Mark about 1/4 full on waste, mount camera high.
Here is one with the spreader light on......
