Factory teak floor
i have a factory teak n holly floor that I would like to pull out and refinish this winter. Looks like it's not secured but just laid in the floor. Is it glued or secured in any way that I need to plan for in removing it? Thanks
The iron certainly helped. Not at all there but we just borrowed a neighboring boats small mini travel iron. Going to bring up our larger iron next week and also may try our steamer. The wet hot rag worked much better than dry. Still assuming worst case is strip and re do inside boat this winter
https://www.waterlox.com/products-item/waterlox-original-UV-protection-marine-wood-sealer
1- Remove stairs, sand small area under stairs down to bare wood. Then put both water based and oil based polyurethane on to see which one matches best. Under stairs is a good test spot.
2- Sand stain area down to bare wood, then treat with a wood bleach. Likely will use barkeepers friend (oxyllic acid) to bleach out the stain.
3- let dry for a few weeks, maybe a month. Then lightly sand entire floor and put 2-3 coats of polyurethane on.
As you can see my plan is not to sand the entire floor to bare wood, just the spot repair the bad spot and re coat entire floor. Concerned about the black stain coming back after re sealing. Any thoughts or concerns?
